Adding footwell lights
Old Jan 3, 2008 | 11:31 PM
unbroken's Avatar
Default Adding footwell lights
Im going to grab a pair at theh salvage yard( Ill get more if anyone wants some)
How to hook them up to come on when the door is open? Schematic?
thanks
Old Jan 4, 2008 | 05:38 AM
bryan04h's Avatar
what do you mean how to hook them up when the door is open? like when the door is open and key is out of the ignition, that they are still on?
Old Jan 4, 2008 | 07:17 AM
blindxeyed's Avatar
Just tap them into the interior lights fuse.
Old Jan 4, 2008 | 07:59 AM
WhiteBird00's Avatar
Ungrounded Moderator
Sure...except the COURTESY fuse is hot all the time.
If you want them to work like the other courtesy lights then you'll have to tap into the circuit from the BCM. The dark blue with white wire in the black connector is 12V power and the white wire in the blue connector is ground. The BCM provides power that shuts off after ten minutes if you leave a door open (to save the battery). It also provides a ground that varies to produce the theater dimming effect.
Old Jan 4, 2008 | 09:24 AM
blindxeyed's Avatar
Ah, yes.. forgot about that. Thanks for catching that lol
Old Jan 4, 2008 | 11:54 AM
unbroken's Avatar
Ok thanks......Sooooooo wheres the BCM at ?
Old Jan 4, 2008 | 11:56 AM
The BCM is a black box about the size of a paperback book mounted under the right side of the dash behind the glovebox.
Old Jan 4, 2008 | 12:47 PM
unbroken's Avatar
Found it...thanks again.
Old Jan 4, 2008 | 05:10 PM
Mike454SS's Avatar
What are you taking them from at the yard?
Old Jan 4, 2008 | 05:58 PM
unbroken's Avatar
I have a friend at salvage yard that lets me have just about anything I need. The GM car section has tons of cars to choose from. I'll look at some of the cars that have nicer lights etc(194 pin style or better) Im also adding a rear mount light from a third gen Fbody-It was located by the trunk release. Ill poke around and grab a bunch. If you want one or two Ill send 'em to you(FREE)
