Questions on the Iron Block 6.0
Old 01-04-2008, 03:16 AM
Gun5's Avatar
Default Questions on the Iron Block 6.0
been doing some reading since I saw some of the iron blocks cheap anyways I figure the LQ4 and LQ9 are the 6.0 iron blocks
Besides one being iron and having different pistons in them they are basically the same block as LSx? LS2 parts can go on the bottom end and LS1 heads can bolt up to it?
and yes I searched the stuff i found was vague
Ryan
Old 01-04-2008, 06:08 AM
s346k's Avatar
yes, basically.
you just have to watch accessories as the lq4/9 and ls1 will not interchange.
Old 01-04-2008, 07:15 AM
ls1leadfoot's Avatar
yes.......heads and everything else is pretty much the same.......alternator mount is diff
Old 01-05-2008, 12:21 AM
Gun5's Avatar
what are they usually going for? I found a fully machined one for $600
I imagine LQ4 and LQ9 engines are the same blocks just different head/piston setups?
Old 01-05-2008, 12:23 AM
spookyz28's Avatar
Ryan
Same block's just different cube sizes, the only difference is that the LS3 block is said to be 20% stronger than the LS2. The ls1 **** will bolt on all those block's
Old 01-05-2008, 12:35 AM
Gun5's Avatar
god this ***** confusing where does the LS3 come into this? I know the LS3 is a 6.2L
