why not bigger tire???
Old 01-04-2008, 03:21 AM
LS1>Imports's Avatar
Default why not bigger tire???
jus wondering why not put a 325 on set of TT2's(17x11's)
cant a 325 fit on an 11?
would it rub?
whats the biggest tire that can fit on a 11
jus wondering cause when i get mine, i want to try a 325?
Old 01-04-2008, 04:04 AM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
I'll say this which does not answer your question: Get yourself some GoodYear Eagle F1 GS D3s in the 315 variety and these tires will more than give you the width you desire. And its a proven set up.
http://www.tirerack.com/tires/tires....e1=yes&place=0
Old 01-04-2008, 08:13 AM
ls1leadfoot's Avatar
yes it is a proven set up.....it depends on what you are trying to acheive......17x11 will accomidate up to a 335/30/17......kuhmo makes the only tire i have found in that size.....if the 315 isnt wide enough......325 is only 10mm wider.....you need to skip 2 sized to visually see the diff....but.....the gsd3's appear to run a little wider than most due to the shoulder construction
i used to have 315's on my stock ws6 wheels and it looked great
good luck
Old 01-04-2008, 10:24 AM
Undertow74's Avatar
your gonna have to bang the **** out of your fender wells. esp if your car is lowered. 325/335 is a wide *** tire! i like my 315's
Old 01-04-2008, 10:45 AM
DopdBrd's Avatar
I don't think they make anything in a 325 that would fit a 17x11. Only sizes I have seen are 315/35R17 and 335/30R17
Old 01-04-2008, 10:56 AM
Kleeborp the Moderator™
MeentSS02's Avatar
Try it and report back. I don't think they'll fit without some serious rubbing issues somewhere, but it all depends on how far your wheels stick out already. My CCWs tuck in pretty tight, so I'd think it would be a no-go for me...
Old 01-04-2008, 11:03 AM
Camaro396's Avatar
I have 325/50/15s on 15x9 centerlines.
Quick Reply: why not bigger tire???
