why not bigger tire???
jus wondering why not put a 325 on set of TT2's(17x11's)
cant a 325 fit on an 11?
would it rub?
whats the biggest tire that can fit on a 11
jus wondering cause when i get mine, i want to try a 325?
would it rub?
TECH Cry Baby BOSS APPROVED!
I'll say this which does not answer your question: Get yourself some GoodYear Eagle F1 GS D3s in the 315 variety and these tires will more than give you the width you desire. And its a proven set up.
http://www.tirerack.com/tires/tires....e1=yes&place=0
yes it is a proven set up.....it depends on what you are trying to acheive......17x11 will accomidate up to a 335/30/17......kuhmo makes the only tire i have found in that size.....if the 315 isnt wide enough......325 is only 10mm wider.....you need to skip 2 sized to visually see the diff....but.....the gsd3's appear to run a little wider than most due to the shoulder construction
i used to have 315's on my stock ws6 wheels and it looked great
good luck
good luck
