Need tips on setting this up?
Old 01-06-2008, 10:20 PM
fccs's Avatar
Default Need tips on setting this up?
Ok so I'm needing a new headunit, sail panel speakers, and the adapter for controls on steering wheel to work. This is what Im thinking of going with.
Headunit:
http://www.crutchfield.com/S-CUXGHf1...ures_and_specs
Sail panel replacements:
http://www.edesignaudio.com/edv2/pro...products_id=33
Steering wheel thing: (Dont know where im going to buy it yet)
http://cgi.ebay.com/PAC-SWI-X-UNIVER...QQcmdZViewItem
And last but not least..a lil appearance mod:
http://maptechenterprises.netfirms.c...a7f9e1ebc5fda1
What do you guys think? Anything else ill need?
Old 01-07-2008, 03:57 PM
fccs's Avatar
bump...
Old 01-07-2008, 04:20 PM
Ungrounded Moderator
WhiteBird00's Avatar
Get the SWI-JACK instead of the SWI-X - it's designed to connect to the wired remote port on the back of that head unit so you don't have to mount an IR emitter.
Don't forget the wiring harness adapter so you don't have to butcher the factory harness. Also, you'll need an antenna plug adapter since GM uses an odd undersized antenna plug.
Old 01-07-2008, 04:49 PM
fccs's Avatar
..always something the wires and such Im not worried about But first off what do most people have for these cars, how do I know if swi is acceptable for that headunit and what antenna plug adapter is this you speak of now?? lol
Old 01-07-2008, 07:49 PM
Look for a listing in the specs that says a wired remote is available. That means it has a port on the back and the 9883 has that option.
The antenna adapter is a standard GM-to-Motorola adapter. It's usually about 6" long with a GM size antenna socket on one end and a normal Motorola size antenna plug on the other. They're available from any stereo shop, auto parts store, or even Wal-Mart for about $9.
Old 01-07-2008, 08:01 PM
mezmerize1's Avatar
if you order the headunit from crutchfield and enter what kind of car you have, they send the antennae adapter, wiring harness, a master install sheet, and i think a mounting kit for free. when you add the headunit to your cart itll show all that stuff in your cart as well.
Old 01-07-2008, 09:41 PM
fccs's Avatar
yea thought it came with it, alright cool now the question remains what do i wanna do about the steering wheel controls... what do most ppl do I mean I dont want anything sticking out of the headunit or stuff like that
