Driving with Bad Clutch???
Old Jan 7, 2008 | 08:57 PM
RareBreed0295's Avatar
Default Driving with Bad Clutch???
Is it ok to drive the car with the clutch going bad? I can feel it slipping a good bit but it is my DD so i need a car? Will it hurt the transmission driving it with the bad clutch?
Old Jan 7, 2008 | 09:16 PM
NHRArox's Avatar
im also interested in this as my clutch is very bad after the day at the track with nitrous on stock clutch
Old Jan 7, 2008 | 09:21 PM
I got the Ls7 clutch sitting in the shop but i dont want to pay a shop 450 just to install my clutch when the motor will be coming out in less than a month for my H/C swap..
Old Jan 8, 2008 | 12:35 PM
anyone else got opinions????
Old Jan 8, 2008 | 12:48 PM
connexion2005's Avatar
You will be fine like that. It actually puts less strain on the gears when you are slipping since the power is not being transferred just do your best to not hammer it and make your clutch last as long as possible before you replace it. I have known people that put atleast 5,000 miles on a slipping clutch and it does not cause problems to your t56. I guess the only real thing that could happen is you could eventually scorch your flywheel so much to where it could not be re-cut but I highly doubt that even that is a possibility if it has never been cut.
Old Jan 8, 2008 | 01:03 PM
Well the flywheel will be replaced when the clutch comes along so i dont got to worry about that. Thanks for the reply.
Old Jan 8, 2008 | 01:06 PM
sloganish's Avatar
you are 100% fine to drive on a slipping clutch, but make sure the damn thing doesn't go completely out on you, because you wont be movin anywhere!
Old Jan 8, 2008 | 01:10 PM
yea..im not getting on the gas too much because of that. I just dont want to spend the extra money when i can do it myself for free.
Old Jan 8, 2008 | 02:39 PM
no lie man...do it yourself and save some green...
Old Jan 8, 2008 | 02:48 PM
I figure it will be a learning experience anyways..i gotta do the motor instlal anyways..get the clutch out the way at the same time.
Old Jan 8, 2008 | 04:33 PM
McAllenSuperSport's Avatar
my master cylinder and slave are shot but I drive the **** out of the car still their pretty strong piece's
Old Jan 8, 2008 | 04:55 PM
SlowZ28/SS's Avatar
It'll be fine till it goes out on you all the way one day. Treat her right till she's fixed.
Old Jan 8, 2008 | 05:56 PM
Yeah. Hard to be easy on the car though if you know what i mean...
