70 camaro ls1
70 camaro ls1
I decided its time to drop a ls1 in my 70 camaro and i was wondering if theres any simple problems that people have by putting ls1's in cars or any pointers i could get also does anyone know what headers will work for this car or will i have to get them custom done
John, I tell you what.. most if not all home swaps (and even shop) are all different. But the good new is that it has been done many time. (search on the Gen II guys)
Check with some of the major vendors and the sponsor here. Many of the Header companys are now starting to make swap header along with Custom SS kits.
While not the same subframe or steering arrangment, most of your "issues" are the same ones you will find in the first gens. Cooling, Wiring, Oilpan clearance, AC location, exhaust routing, locating the crossmember, and shifter location, Speedo hookup, Tach hookup, Computer Programming, FUEL DELIVERY. Should not be a super difficult swap, there are several second gen swaps on the site. ALso, for pretty detailed overall installs, there are a few good threads under the hall of fame sticky, plus look up Rodder's swap notes as well. You should have a pretty easy go....
yeah it has a 402 in it that gets a few miles to the gallon and i wanna daily drive this thing or just be able to take it on trips and stuff instead of pulling it and i love my 98 with the ls1 and just figured i would challenge myself a little bit and do an ls1 swap
I agree with Cam72aro... After doing my swap and driving it for the past year.. FI is for me.. at least for my Chevelle which is used for cruz'in and nightly drive in's. Even with 4.10 I still get 23+ on the highway... ! lets see you do that with a carb setup. !
Most of my buddies are still driving there big cam'd and carb'd classic.. but they have to fill up 2-3 times before i even think about it..
As far as a Challenge in swapping in the physical engine and trans.. that is almost as easy as going from a sbc to a bbc or bbc to a sbc with the amount of swap hardware out there now a days ! It will only be as hard as you try to make it and that goes for the Cost of doing a swap.. low cost basic swap it in or bling it out..!
Check this thread out:
https://ls1tech.com/forums/conversions-swaps/472609-lsx-into-67-69-camaro-basics.html
Might be helpfull.
Might be helpfull.
