Factory alarm keeps freaking going off!!!!!!!
i have a factory alarm and every single time i lock the car it goes off within 10seconds. I lock the car from the remote...it goes off...i lock the car with the lock button on the door...it goes off...i lock it with a key...it goes off. Anybody have any idea what the hell is going on??? I cant lock my car so its just a little bit of a problem haha thanx for the help guys
Ungrounded Moderator
Chances are that the shock sensor is causing the problem. Disconnect it and see if the problem goes away. Also, you must have passive arming programmed otherwise the alarm wouldn't arm when you lock the doors with the key. You can change the programming so that the alarm only arms when you use the remote or the power lock button.
This happened to mine a couple weeks ago (Factory Alarm Also). On mine all it was was the batteries in the remote for the alarm were bad. I changed them out and every thing was back to normal. It's that or the shock sensor.
