Which wiring harness adapter?
The sticky says to use this one: "70-1858 Pro Wire harness for 1993-02"
Where is this part number for?
Can I use the $20 one from Best Buy?
you can save yourself a few minutes or more depending on your soldering skill level by purchasing the MET-801858 and then a brand harness which will simply click together without soldering, crimping, heatshrinking.
