still having clutch problems
Old 01-12-2008, 10:41 AM
stevensLS1's Avatar
Default still having clutch problems
here's the setup first. stock hurst w/LSS mcleod twin disk with mcleod master, 00 slave ( 6k miles) when the car is cold the clutch pedal feels soft and has play in it. also the shifts are somewhat sloppy. car is hard to get into reverse also. once the car warms up to regular temp problem goes away.
does anyone have any ideas here?
Old 01-13-2008, 01:06 AM
88zukon36s's Avatar
mine will feel soft when it is cold also, once it warms up all is good..
Old 01-13-2008, 04:05 AM
stevensLS1's Avatar
well glad im not the only.
anyone have any reason for this?
Old 01-13-2008, 04:24 AM
OMGWTFBODY's Avatar
Fluids perhaps?
How cold are you having problems with it?
Old 01-13-2008, 12:39 PM
stevensLS1's Avatar
this was when it was in the 40s and high 30s. but just regardless if the car is just started up for the day it will do it till it gets to full temp. ive check the res.and its full of fluid.
Old 01-13-2008, 05:42 PM
wrencher
wrencher's Avatar
McLeod master for sure.
Mine does the same thing but not that excessive.
I usually pump the freeplay out of it & it is fine.
I have also rebuilt mine/ honed out the master etc. Then keep the fluid clean with perodic flushes, it helps.
Old 01-13-2008, 08:32 PM
LS1Tech Sponsor
Slowhawk's Avatar
It's the master cylinder.They are famous for that problem.
Old 01-13-2008, 09:36 PM
Viper's Avatar
I've got the same problem, just rebuilt the McLeod master, bench bled it AND mityvac'd it. Still have play in the top for about an inch or two and high rpm shifts are hit or miss; many times it won't let me go into gear. Is it time to replace the master? I was going to replace the slave in the spring thinking that was the problem but if I don't need to pull the tranny I'd rather not. I may just go back to a stock GM master if I replace, I have the drill mod done since 2002.
Old 01-13-2008, 11:11 PM
wrencher
wrencher's Avatar
You need to adjust that freeplay out to a minumum. You need to leave a little play in there, but this will help your problem.
Old 01-14-2008, 01:27 AM
nvmy2000ss's Avatar
What slowhawk said +1
Old 01-14-2008, 06:14 AM
Viper's Avatar
"You need to adjust that freeplay out to a minumum. You need to leave a little play in there, but this will help your problem."
How? I mean the engagement point can move because it's adjustable and all, but I didn't touch it when i rebuilt it, it stayed at the same point.
Old 01-14-2008, 04:06 PM
stevensLS1's Avatar
this master doesnt even have a year use on it. maybe 4-6k miles on it honestly.
Old 01-14-2008, 11:58 PM
wrencher
wrencher's Avatar
Doesn't seem to matter, they can go bad even quicker.
I had problems w/ mine even sooner that that milage as well as others here.
Old 01-15-2008, 12:06 AM
wrencher
wrencher's Avatar
If you adjust it to get the freeplay to a minumum it will get the fluid flowing that much quicker once the pedal is depressed.
That is what the real adjustability in the master is for, not tailoring the pedal release point.
Leave alot of freeplay in the pedal release is low & high rpm/quick shifts are more difficult or impossible.
Adjust all the freeplay out & you are riding the slave on the pressure plate w/ varied amount of pressure during driving.
Kinda like riding the clutch a tad if you will, so a little freeplay hot in the pedal is a good idea IMHO.
Read the stock adjustable master sticky, in the first post at the bottom, there is a adjustment recommendation.
Old 01-15-2008, 03:28 AM
stevensLS1's Avatar
so would it be worth just putting a stocker back into its place? i cant believe this $300 ( i think) part would just fubar so quickly
Old 01-15-2008, 04:50 AM
Viper's Avatar
Thanks wrencher.
Old 01-16-2008, 04:38 AM
stevensLS1's Avatar
well this morning it was raining and i stepped on it and the clutch felt really really soft. is it gone? and can i use a stock piece and still work fine? thanks
Old 01-16-2008, 08:07 AM
wrencher
wrencher's Avatar
I have heard mixed results using the stocker w/ the twin disc McLeod.
I wouldn't want to find out the hard way IMO. I would rebuild the master.
No matter what your gonna need the adjustability in there, the stocker wont give you that unless you mod it.
Is it adjusted up right now? Have you tried to flush the fluid??
Old 01-16-2008, 04:54 PM
stevensLS1's Avatar
im really not sure if its adjusted. i had a local shop put it in and was working fine till a few months ago. now this morning the pedal just felt really soft. havent done the fluid flush either.
