Oil Pressure Gauge Pegged
Old 07-06-2003, 09:03 AM
C5Rookie's Avatar
Default Oil Pressure Gauge Pegged
Car runs/drives perfectly, but the analog oil gauge is pegged at 80. Dashboard computer display says 128/129 PSI at startup and during driving. Gauge does drop to 0 at cut off. My friend is putting it on the AutoTap later today for a look. No check gauges indicator lit. I figure it's an electronics problem, but wanted expert opinions!
I admit to buying car with this issue, but have full warranty if this means bad trouble, and fellow Corvette owners tell me the car is in great shape otherwise. No prior repair details.
Thanks for tolerating a rookie question!
Old 07-06-2003, 10:48 AM
roguevegals1's Avatar
Default Re: Oil Pressure Gauge Pegged
when i put the new motor in mine did this. i found that it was a ground. check the ground on the back of the drivers side head. maybe that could be ur problem.
Old 07-06-2003, 07:51 PM
C5Rookie's Avatar
Thank you for the info. AutoTap read 4.5 volts steady while driving, which translates to 129 psi..so the gauge is OK, but something feeding the sender or the sender is not.
Old 07-06-2003, 11:24 PM
felton316's Avatar
If the sender broke or is unplugged it will peg the gauge.
Old 07-07-2003, 12:00 AM
jmX
jmX's Avatar
The sender is broke, or unplugged, like felton316 says.
Happens all the time.
Old 07-07-2003, 12:37 AM
Smoke_Ford's Avatar
Yup, sounds like an electrical issue.
Quick Reply: Oil Pressure Gauge Pegged
