motor fires only on one side?
does anyone know could cause my engine to fire on 2 4 6 and 8 but not on 1 3 5 and 7?
it ran fine the other day. and my buddy just came home from iraq and wanted to check it out so i went to fire it and i could hear only one side firng and the pipes on the driver side were cold.
i checked the wiring and the pink wires on each coil are get 12 volts so i figure it must be a triggering type issue, but don't know what to check.
1 Post
Originally Posted by leonpiper69
if my batt voltage is a little low could that cause weird stuff like that?
I'm still on the "steep part" of the learning curve WRT these engines, but I'd say look at those things where each bank of the engine is handled by a separate part/sensor - things like like coil or injector harness connections, grounds, etc.
Honestly, the 1st question that comes to mind for me is "Has anything changed recently?"
EDIT: Here's a "dumb" question for ya - if you swap the coil harness connection over from one side to the other (or swap coils/parts), does the problem follow the swapped parts? (I'm still in the 'parts gathering' phase of my build, so if swapping coil harness sides isn't possible, try not to laugh too hard...)
Good luck.
the only thing diff since it ran is i relocated the part of the harness for the driver 02 sensor, because it was down by the alt and i "carefully" cut the old factory tape holding it together and rerouted that.
i looked for any cuts in the wire, my bud checked too and we found nothing.
plus even if i had cut one wire it would still run on the other 3 coils on that side, no?
next im going to trace the 4 wires that trigger each coil from the pcm to the coil and make sure i have a connection, it just drives me nuts cuz think that we will a waste because if one didnt have a connection, again the other 3 should still fire.
maybe i'll just pull my hair out, i need a hair cut anyway.
1 Post
(Heh - xssive & I are on the same page...)
