K member swap
I don't think there is a whole lot of weight savings in the a arms, so I'm guessing most of the weight in the paragraph below from BMR is in the K member. Bob
BMR Tubular K-members are designed to provide a lightweight alternative to the factory K-member as well as provide additional clearance for aftermarket headers and turbo systems. Our unique design on our V8 models feature integrated frame stands that replace the factory cast iron frame stands. This additional weight reduction allows us to use larger diameter tubing and thicker mounting plates for additional strength over the competition. This means that you can use the K-member for street use, road race, autocross, or drag strip use. BMR K-members are built exclusively using larger diameter 1-5/8" x .120" and 1-1/4" x .095" tubing yet still remain up to 7.5 lbs. lighter than the competitions due to our integrated mount design. Using our tubular K-member and upper/lower a-arm set, expect a minimum weight reduction of 42 lbs. Combine this with a coil-over style spring/shock combo and a lightweight front brake setup and lose over 100 lbs. off the front end! Available in Black Hammertone or red powdercoat
