Can anyone help troubleshoot knock/ping?
Old 07-07-2003, 12:33 AM
J9_ls1's Avatar
Default Can anyone help troubleshoot knock/ping?
I was on it today in 2nd gear, at about 4800 rpms
First of all, I can't distinguish between knock and ping, so I will describe the sound. I got what sounded like someone hitting a piece of metal with a hammer randomly. I believe this is knock, however I am not sure. Does anyone have any idea how to fix or correct this problem? I added fuel treatment, and it is still there. My mods are FIPK pretty much on the engine. I would guess that the engine leaned itself out, but I can't seem to find what would cause a lean condition with my few mods. This has never happened, and definitely never at WOT. Any suggestions would help, I do not believe my mods are the cause.
Thanks
Jason
__________________
Old 07-07-2003, 12:36 AM
Smoke_Ford's Avatar
Default Re: Can anyone help troubleshoot knock/ping?
If the car was knocking, you'd hear it at all RPMs, also, constant oil pressure fluxuation would be an issue.
Old 07-07-2003, 01:03 AM
J9_ls1's Avatar
Sometimes I do get a little fluctuation when I idle. But never while I am driving. This is just noticeable at WOT at higher RPMs though.
Old 07-07-2003, 03:24 AM
Jabroni's Avatar
Do you have ported MAF ends? If so, swap them back and see if that cures it. High RPM pinging can be caused by them sometimes.
Old 07-07-2003, 06:42 AM
J9_ls1's Avatar
No,my maf and TB are both stock still
Old 07-07-2003, 03:56 PM
J9_ls1's Avatar
No other ideas? Anyone got any ideas?
Old 07-07-2003, 05:14 PM
robertbartsch's Avatar
fill up with 93 octane, add some fuel injector cleaner, consider using a colder thermostate
...if this does not help, try a GM top cleaner or other carbon build-up cleaner...
..when pinging ocurs, the CPU shifts to a different set of fuel air mixtures....these are retained, until the gas tank is filled...
