newbee t56 question
Old 01-20-2008, 09:20 PM
383lt1impala's Avatar
Default newbee t56 question
ok the other day i bought a camaro and on the freeway the clutch pedal got stuck is there anyway to fix it quickly so next time i dont have to get a tow truck and sorry for the newbeness lol. and whats the best way to drive a stick on the street and the strip.
Old 01-20-2008, 09:24 PM
and again 4give me 4 the newbeness the day i bought it was literly the 1st time i drove a stick car i can drive big rig 9+ speeds. but hardly anything like a street car.
Old 01-20-2008, 10:51 PM
01bad ss's Avatar
My clutch pedal only sticks to the floor when I powershift 1st to 2nd with my drag radials on back.I usually try to get the trans into neutral and pull the pedal up with my foot.Best to fix problem by replacing slave,replacing fluid and doing drill mod.If you dont repace parts just dont build a lot of heat in the clutch by slipping or powershifting.
Old 01-21-2008, 06:01 AM
Internet Mechanic
BlackScreaminMachine's Avatar
like said, there is an issue with your hydralics. Being thats its a older camaro, id do a 2001+ update, wrap the clutch line, use DOT4 syn fluid and bleed it properly. As long as the clutch is in good condition, you should not have this problem at all.
Also there is a clutch return spring which is VERY hard to get to but make sure its replace when you do the master.
Old 01-21-2008, 09:12 AM
Well I bought it from a shop they did the m6 conversion everything has about 300 miles on it including the spec 3 clutch and the mcloed master. And lets say that happens to me again all I do is let it cool down and try to pull the pedal back out? Cuz I had to get a tow truck even thought the shop I got the car from is taking care of everything who knows where that can happen to me again.
Old 01-21-2008, 09:44 AM
Internet Mechanic
Its a fluid issue, its needs to be re bleed, and checked regularly.
Old 01-21-2008, 02:55 PM
any1 know if the 2002 master and slave cyliender will be able to put on with no problem?
