Head gasket
Head gasket
I am doing H/C and wanted to know what head gasket you guys recommend?
It's a stock 346 LS1. I will be doing either PRC 5.3 2.5's or AFR 205's and an MS4.
I see alot of people using Cometic .040's. Are these good and where would I purchase them? Or would just the stock GM gaskets work well?
Thanks!
Thanks!
I went patriot stage 2's and was told to go 4100ths gasket to bump up the compression in theory now other then that the GM gasket is a verry good gasket and can be reused I have a set of GM ls6/ls1 head gaskets right here if you want them they will work on your car thier still in the package they were just a little thicker then what gunner advised. PM me if you want them I just havent sent them back to thunder yet.
I am running the .040 cometics and I went with this thickness specifically to get my compression and quench where I wanted it. It's best (imo) to go with a thickness that is the best match for your combo.
I prefer the GM MLS gasket they are cheap to replace if you ever need to at around 20 dollars a gasket. The Cometic gaskets are nice, but they cost 80 a piece.
What's the thickness?
Thanks
Well it depends on the power you are making and the cylinder pressures. The MLS gaskets tend to hold up a lot better to intense pressure versus a graphite gasket. Then you have the whole gasket thickness to help you get the CR you desire.
LS1Tech Premium Sponsor
Just an FYI, the MS4 will not clear with the PRC Stage 2.5 5.3L heads without flycutting the pistons. You would have plenty of clearance with the MS3 however. Or the stage 1 heads would clear as well.
We've got numerous options for you that will not only have PtoV clearance, but will make gobs of usable power too! Give us a call or shoot me a PM if I can help!
*EDIT* We also offer the GM graphite and MLS gaskets as well as a full line of Cometic MLS head gaskets. We'll help you select a gasket with the correct thickness to optimize the quench on the motor which helps ward off detonation issues.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Magic words.......Usuable Power!!!!!!!
No sir, the MLS gaskets work just fine!
__________________
OLD THREAD. We've got all the gaskets in stock. Call us if we can get you a set sent out
__________________
