Head gasket
Old Jan 21, 2008 | 01:54 PM
98RedBird's Avatar
Default Head gasket
I am doing H/C and wanted to know what head gasket you guys recommend?
It's a stock 346 LS1. I will be doing either PRC 5.3 2.5's or AFR 205's and an MS4.
I see alot of people using Cometic .040's. Are these good and where would I purchase them? Or would just the stock GM gaskets work well?
Thanks!
Old Jan 21, 2008 | 03:20 PM
BLACK2001SS's Avatar
I went patriot stage 2's and was told to go 4100ths gasket to bump up the compression in theory now other then that the GM gasket is a verry good gasket and can be reused I have a set of GM ls6/ls1 head gaskets right here if you want them they will work on your car thier still in the package they were just a little thicker then what gunner advised. PM me if you want them I just havent sent them back to thunder yet.
Old Jan 21, 2008 | 04:36 PM
DaveX's Avatar
I am running the .040 cometics and I went with this thickness specifically to get my compression and quench where I wanted it. It's best (imo) to go with a thickness that is the best match for your combo.
Old Jan 21, 2008 | 07:57 PM
Sigforty's Avatar
I prefer the GM MLS gasket they are cheap to replace if you ever need to at around 20 dollars a gasket. The Cometic gaskets are nice, but they cost 80 a piece.
Old Jan 21, 2008 | 10:09 PM
98RedBird's Avatar
How much ya want for them?
What's the thickness?
Thanks
Old Jan 21, 2008 | 10:10 PM
98RedBird's Avatar
So, does the head gasket really matter. I mean, I just usually use stock GM gaskets on everything....
Old Jan 21, 2008 | 10:16 PM
Sigforty's Avatar
Well it depends on the power you are making and the cylinder pressures. The MLS gaskets tend to hold up a lot better to intense pressure versus a graphite gasket. Then you have the whole gasket thickness to help you get the CR you desire.
Old Jan 21, 2008 | 10:21 PM
98RedBird's Avatar
What size are the GM's?
And I plan on making in the neighborhood of 450rwhp N/A and around 550+ on the spray... what would you recommend
Old Jan 21, 2008 | 10:28 PM
405HP_Z06's Avatar
The stock MLS are .053 and will hold up to the power levels you describe. As Sigforty stated, they are a good gasket for the money and are readily available.
Old Jan 22, 2008 | 08:40 AM
Sigforty's Avatar
Well put, and just to add I am making over 600 rwhp on the gm mls gaskets.
Old Jan 22, 2008 | 09:13 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Just an FYI, the MS4 will not clear with the PRC Stage 2.5 5.3L heads without flycutting the pistons. You would have plenty of clearance with the MS3 however. Or the stage 1 heads would clear as well.
We've got numerous options for you that will not only have PtoV clearance, but will make gobs of usable power too! Give us a call or shoot me a PM if I can help!
*EDIT* We also offer the GM graphite and MLS gaskets as well as a full line of Cometic MLS head gaskets. We'll help you select a gasket with the correct thickness to optimize the quench on the motor which helps ward off detonation issues.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jan 22, 2008 | 09:32 AM
02 BLK WS6's Avatar
Magic words.......Usuable Power!!!!!!!
Old Jan 22, 2008 | 12:42 PM
98RedBird's Avatar
I will be calling you guys tomorrow! Thanks
Old Jan 22, 2008 | 01:23 PM
Unstang's Avatar
Matt@Texas-Speed,
Do the 5.3 heads require the graphite gaskets, instead of the MLS?
Old Jan 22, 2008 | 01:24 PM
Originally Posted by Unstang
Matt@Texas-Speed,
No sir, the MLS gaskets work just fine!
__________________
Old Feb 5, 2009 | 08:50 PM
1fastmofo's Avatar
anybody by chance know the part number of the mls gm gasket?
Old Feb 5, 2009 | 09:06 PM
405HP_Z06's Avatar
Which GM MLS gasket?
Old Feb 5, 2009 | 09:18 PM
1fastmofo's Avatar
good question i am not sure what one i need i have a stock 98 ls1 and am trying to install the tsp 2.5 5.3 heads
Old Feb 6, 2009 | 09:21 AM
OLD THREAD. We've got all the gaskets in stock. Call us if we can get you a set sent out
__________________
