Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
FS: 1994 Formula
Old 01-21-2008, 04:22 PM
Next level's Avatar
Default FS: 1994 Formula
This car has been put on sale for a good month or so. I have every single document for the car. This car has 13K into it. Here is the part list, the pics and the price. The motor has never been sparyed tho can hold a really good shot never had the urge too. The Body has 89,xxx miles on while the motor, transmission, and rear end only have 7,500 on it.
Engine - 396 Storker Motor
- Eagle 3.8750 stroke crank
- Eagle 6.00" rods
- The block is bored .030 over
- Has splayed 4 bolt main caps
- All arp main bolts and head bolts
- .236/.245 .575/.595 Custom Ground Cam (112 LSA)
- 58MM BBK Throttle Body
- Ported Heads (I have the Flow Sheet)
- Accel Optispark
- Taylor 8MM Wires
- NGK Plugs
- Brand New Coil (2 days old )
- 36 LBS Injectors
- New GM Oil Pump
- A/C Delete
- SLP Fan Switch
- SLP Elbow
- Morso CAI
- New Alty and Battery
- New Refab Duralast Starter
- Dnyatech Lontubes into a 3 inch Y-pipe over axle dual SLP Slash Tips (no cats)
- Polyuthren Engine Mounts
- Emissions are GONE
THe car has had regular Oil Changes of 1,500 miles with Royal Purple 10w - 30
motor was dnyotuned at Slingshot Motorsports in Fox River Grove,IL
Car dnyoed at 418HP and 467TQ
Also, have been down to the track many times and have many time slips to prove how fast it is. The last pass with this car was 7-13-07 and ran 11.72 @ 119MPH and .60ft a 1.51
Tranmission - 4L60E (Freshly Redone)
- 2800 Vigilante Stall
- TCI Flexplate
- Brand New Bands, Clutch packs, and just flushed with Royal Purple Trans Fluid
- Transpack Shift Kit
Rear End - 10 Bolt
- 3:73 Richmond Gear
- Eaton Posi
- Upgraded Axles
Suspension - Almost Complete
- BMR Sub-frame Connectors
- BMR Lower Control Arms
- BMR Panhand Bar
- EdleBrock Torque Arm
- Eibach Front Drag Springs
- Energy Suspension Trans Mount
- New Polyuthren Rear End Bushing
Misc
- Warbird Hood
- LS1 Tail Lights
- Matching Blue vnyle (bird Fill-in, Pontaic Fill-in etc....)
- Limo Tint All around
PICS
The body of the car has no rust. It did have a problem in the shop and has a small crack on the passanger fender, the arm on the lift it what caused it. Other then that there are no Imperfections in the body at all. I can also post a pic of the crack upon request.
Im asking $9,000 o.b.o
will sell out of state but must be in midwest, also will consider trades
Old 01-30-2008, 05:27 PM
GreenBlood's Avatar
is it clear of all emissions testing?
Old 01-30-2008, 05:28 PM
GreenBlood's Avatar
do u still have the parts for the A/C?
Old 01-30-2008, 09:45 PM
CHRRRIS's Avatar
I think all vehicles made 1996 and earlier are free of emissions.
Old 01-31-2008, 02:57 AM
GreenBlood's Avatar
yea, as of january first, but do they need to be tested one more time before they are cleared? my cars emissions is up in june of this year, can i rip these cats off or no?
Quick Reply: FS: 1994 Formula
