CME Question
CME Question
I have the slp cme tips and plan to match it with my gmmg. I saw SLP has a 90 degree bend for sale but it only says left side.
Can I order two of these? Will they match the cme to my gmmg?
http://www.slponline.com/view_produc...63&BIG=10863-1
I am not sure if it will work with the CME. You can give SLP a call or do a search and see if anyone on here has used it. That custom setup has been done several times, so I am sure someone knows.
If they don't work I would take the car to a reputable exhaust shop and them make everything fit.
Cme
No They Are Not The Same,
There Is A Left Side, And Ther Is A Right Side.
YOU CAN SEE IN THE PICTURE THAT ONE PIPE IS STRAIGHT THEN TURNS 90 DEGREES TORWARDS THE END, AND THE OTHER CURVES THROUGHTOUT THE PIPES 90 DEGREE BEND.
