ls7 clutch on a ls1
ls7 clutch on a ls1
ok the question i had is for the pressure plate and the fly wheel which bolts can you use? like will the stock ones fit or do you need other ones and if so what kind?
Location: Your girl's back door giving her the long stroke while you're at work
The clutch kit will come with the bolts to mount the pressure plate and flywheel together. I used the stock flywheel bolts when I installed mine
