ls7 clutch on a ls1
Old Jan 24, 2008 | 12:10 AM
fuseone's Avatar
Default ls7 clutch on a ls1
ok the question i had is for the pressure plate and the fly wheel which bolts can you use? like will the stock ones fit or do you need other ones and if so what kind?
Old Jan 24, 2008 | 12:27 AM
SladeX's Avatar
the stock ones work, but ARP bolts are so cheap and good insurance. Don't forget to use RED loctite on them.
Old Jan 24, 2008 | 12:45 AM
fuseone's Avatar
ok but if i were to order them would i order them for a ls1 or ls2 or ls7 bolts like which kind is more of what i was asking.
Old Jan 24, 2008 | 01:13 AM
Krab's Avatar
Yes, you can use the stock flywheel and pressure plate bolts when installing an LS7 clutch. I'd order the ones for an LS1.
Old Jan 24, 2008 | 01:14 AM
fuseone's Avatar
ok just wanted to make sure thanks for the help.
Old Jan 24, 2008 | 09:19 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
The clutch kit will come with the bolts to mount the pressure plate and flywheel together. I used the stock flywheel bolts when I installed mine
Old Jan 24, 2008 | 04:54 PM
Krab's Avatar
Who'd you get your clutch kit from? Mine didn't come with any bolts...
Old Jan 24, 2008 | 10:10 PM
Z28/2002's Avatar
Scoggin Dickey or atleast I thought it had them. It's been a year since I put it in
Old Mar 6, 2008 | 08:57 PM
Gun5's Avatar
so the stock LS1 bolts will carry over to a LS7 clutch setup.. and just reuse the pressure plate to flywheel bolts
Old Mar 6, 2008 | 09:27 PM
TheLS1Kid's Avatar
Yes I just did mine 2 weeks ago.
You can reuse all the bolts (flywheel to crankshaft and pressure plate to flywheel).
Old Mar 6, 2008 | 11:32 PM
dansean1's Avatar
Yes, just buy Scoggin Dickey assembly and you're good to go.
