Custom Radiator
Not too bad. I used to work for a radiator manufacturer. Are the tubes oven brazed to the tank plates? Could you post a pic from the opposite side from the fans.
Dumb question? Why are you blocking off all that area on the radiator? If you don't need it you could just shrink that whole unit down much smaller.
The welding job looks pretty good.
This is a bar and plate setup like your typical intercooler. This is not the typical fin and tube setup on all radiators.
Not sure what you mean by blocking off? This was built and speced as per the 05-06 GTO radiators. But these are 3in Tanks.
Main reason for getting a radiator like this is because the first time you lift and head and blow boost into the coolant system your going to blow the radaitor. Been there done that. Another added factor is better cooling. The fans are setup with there own bank so its not pulling from one side or the other.
Those that are interested on the specs
This setup has 3IN tanks 2 1/4 Core with Dual 11" Spal Fans flowing 1300cfm each . 27" core. Mine fits in the stock location and can be hidden under the plastic peice that goes over the radiator.
custom radiator FTMFW!!!
Have You Installed Your Custom Radiator . If So How Is The Cooling Going , What Temp Are You Seeing. I Have A Custom Radiator Cost Me 1000 But We Still Have Temp Issues . I Hope Its The Radiator Not The Block ( Warhawk ). Engine Has Made 990 Rwhp.
