Where can I go for Amp/Sub Install?
Zup fellas! i finally got an amp and sub. Anyone know where I can go to get it hooked up for a great deal? I really wanted to do this myself but i'm clueless about amp/sub installation! SO far I'ved gotten $60 for the install. Thanx!
I'll teach you how to do it and that will be payment enough... I like installing...haha.. Hmm, I would recommend at Circuit City but there's one like 2 blocks away from me and I could go and help you pick one out so that you get the right size.. So what all does your "system" consist of?? How many amps, what kind, subs, anything else...
That's cool I actually want to learn! I know the amp has 400W but not too sure on the brand and 10' sub is a Fosgate. My HU is a Alpine CDA-9856(I installed it myself). I actually have another 10' sub but I want to start with just one. That's about it! You live in San Diego?
Let me know when you have time! I have Weekends open. Do you want me to drive over there or you drive over here? Also How much do you think i'll spend on material? Thanx!!
I can do it next weekend... Well it really depends on what kind of amp it is... I would like to see it first and go with you to get the power kit so that you get the right one and also figure out where you want to go with it in the future... If you're just going to have that amp then maybe an 8 gauge kit but if you're going to be doing two or more then atleast a 4 gauge... If the amp you have is that big then we'll need a 4 gauge too... Did you already buy your RCA's?? I would say that you're going to spend at least $40-$50 on a good power kit... It's expensive but very worth it when you're done.. Oh btw I solder everything so that it doesn't come apart and I'll make sure everything is tucked away.. Some places that you take it to don't even do that...
wut up arnee ur putting sounds its real easy u can get the install kit real cheap at 11 st and central in l.a for like 8 dollars a real good one that would cost like 25 in the store if u want ill go with u to la to go buy it its not far from lynwood that were i get all my sounds its cheap and its all brand new its whole sale price lol
These are the specs on the Amp!
Performance Teknique ICBM-772
2 Channel
Bridgeable
Power Amplifier
800W max
Max Power Output:
400W x 2Ch @ 2 Ohm
Power Output:
175W x 2Ch @ 2 Ohm
125W x 2Ch @ 4 Ohm
350W x 1Ch Bridged
• 24dB/OCT. Crossover Slope
• Variable Subsonic Filter (10Hz-100Hz)
• Variable Low Pass Filter (30Hz-500Hz)
• Variable High Pass Filter (50Hz-1KHz)
• Variable 18dB Bass Boost
• High and Low Level Input Through RCA
• Double Sided PCB
• Dual Protection (Thermal & Short Circuit)
• RCA Line Out (Preamp)
• Power & Diagnostic LED Indicator
• 2 Ohm Stable Stereo
• Soft Delayed Power On
• Tri-Mode Capability
• 0.05% THD
2 Channel
Bridgeable
Power Amplifier
800W max
Max Power Output:
400W x 2Ch @ 2 Ohm
Power Output:
175W x 2Ch @ 2 Ohm
125W x 2Ch @ 4 Ohm
350W x 1Ch Bridged
• Double Sided PCB
• 0.05% THD
I'm as close as you can get Arnie, let's meet up and I'll take take of it for you!!
the charge is a cold six pack.
It's alot easier than you think, you've already heard my system before.
