do you need main studs?
Old 01-27-2008, 10:59 PM
Boosted1320's Avatar
Default do you need main studs?
The main bolt configuration, is it really nescesary to put studs in? are they that much more stronger? Has anyone had a stock bolt configuration fail? and what HP level did you see that?
Old 01-27-2008, 11:23 PM
SSMOKIN_Y2KSS's Avatar
not sure 100% on the specifics but i mean how much money is it gonna cost you to change them to studs...200$ is it worth not spending the money.i did em..just an opinion
Old 01-27-2008, 11:52 PM
99mongooSS's Avatar
Im gonna be runnin a 300 shot on my forged 347, Im using head studs for sure. As well as ARP everything else from the head studs to the oil pan.
Old 01-27-2008, 11:54 PM
same here 100% arps...top to bottom ...engine to wheel studs lol
Old 01-28-2008, 12:30 AM
99mongooSS's Avatar
its the only way to go with alot of spray.lol. But hell even on a N/A motor they are worth it IMHO
Old 01-28-2008, 04:43 PM
Now are you guys using them because of hear-say and because they are available? Or do you actually need them and they serve a major purpose? I have a 700hp boosted engine now with a stock main bolts and it has not came flying out yet. Thank you guys for answering, but you guys lack explanations that I seek. How much HP does it take to make the stock bolts fault?
Old 01-28-2008, 07:30 PM
ChucksZ06's Avatar
I do not think you need them assuming the stock bolts are installed according to gm specs and have the correct stretch on them. A lot of people on these boards use more than they need cause it makes them "feel" better...like porting and shimming the oil pumps without considering the size of the oil passage in the block that the oil is pumped into or having more pressure than necessary and wasting hp or pumping the oil out of the pan and actually starving the bearings. I like studs cause the torque is applied to the steel threads of the stud rather than the soft aluminum of the block. Is your truck turboed or supercharged?
