433 gear in a A4 car
Old 01-29-2008, 03:33 PM
neals98's Avatar
Default 433 gear in a A4 car
Yes i did a search I am planning on putting a 9 inch in my car. I have found one that has a set of 433 gears in it. Would it be ok in my car...
Old 01-29-2008, 08:37 PM
BOLO's Avatar
4.30's are fine if you're going to run an all motor set up.
I think Rick Abare runs a built LT1 383, solid-roller cam in the 263/267 dur.@50 .654/.610-inch lift, 106 lsa.
He runs an A4 4L60E/4300 stall/4.30 gear in a Moser 9",spool.He's in the 9's@139mph.
Old 01-29-2008, 10:29 PM
GregWS6&z28's Avatar
you will probably need taller tires
Old 01-30-2008, 04:36 AM
EPP
EPP's Avatar
We have 4.30 gears in our 95 Formula that has an LT1 in it. With 28" tall M/T ET's, we're about out of gear in the 1/4 mile with the internally stock engine. You can check it out here.
http://www.exoticperformanceplus.com...tCar.php?car=7 Bob
