oil and coolant in tail pipes
Old 01-29-2008, 06:47 PM
sl99ls1's Avatar
Default oil and coolant in tail pipes
my friend has a 99 z28 and he has oil and coolant in the tail pipes and when he drives it it smokes and the engine light flashes after 40 mph. when he starts the car it back fires and pop. what do you guy think is wrong with it ?????
Old 01-29-2008, 07:05 PM
LS1-450's Avatar
@ Minimum, blown head gaskets
Old 01-29-2008, 07:25 PM
sl99ls1's Avatar
what else can it be???
Old 01-29-2008, 09:08 PM
sl99ls1's Avatar
I Did A Search A I Saw Something About The Pcv System Wahst That About
LS1-450's Avatar
You've got to pull the heads to know for sure. We can only speculate. Could also be head or block damage. My best guess & easiest to fix is a blown head gasket.
Old 01-29-2008, 09:14 PM
5w20's Avatar
i don't know how the PCV has anything to do with coolant but yea i would a leak down test and at minimum a compression and coolant pressure tests.
Old 01-29-2008, 09:17 PM
Black_Bird's Avatar
He's in some trouble, forget about the PCV system. Why is he still starting and driving the car? Park it and get the heads off and see what's going on.
