Which one
Which Master on OZ700?
What master cylinder are you OZ700 guys using? Tex says gm,installer says Ram adjustable. I bought the stock one but I don't want the disengagement issues i've heard about. Advise appreciated.
When I installed my clutch I was still running the stock master cylinder with 70k on it. I could drive around normally with no shifting issues whatsoever, but when I tried to shift at high rpm's it would not let me. I called Textralia and they recommended I follow the sticky on how to make the stock unit adjustable. I bought a new one and did the conversion and problem solved. I was informed that the stock unit normally will not cause any trouble.
