Anyone running the T-REX cam??
Old 01-31-2008, 12:18 AM
jt76's Avatar
Default Anyone running the T-REX cam??
I was thinking about switching to this cam for the summer. I was debating about doing heads, but i am going to hold off because i plan on doing an FI buildup in the not so distant future. What kind of HP are you guys getting? what are your experiences with it?
Old 01-31-2008, 12:27 AM
chuckyt1's Avatar
I love it. PRC LS6 heads, milled .030, making 462/413. Lots of people using this cam with good results...
Old 01-31-2008, 12:31 AM
jt76's Avatar
did you have to fly cut? i herd from a local guy that this is a potential issue
Old 01-31-2008, 12:37 AM
chuckyt1's Avatar
Oh yeah. It's close even with unmilled heads, I milled the heads, used 2.02 valves and an .045 Cometic gasket. Flycutting is not that hard to do. Well worth it in my opinoin.
Old 01-31-2008, 12:43 AM
jt76's Avatar
Yeah the more i hear about the cam the more i like it.. on thunder racing's website they had a car with full exhaust, Ls6 manifold and the Trex and it made 451rwhp... thats impressive.... how is the streetability of the cam... with a tune how is it, say at stop lights? does it wnt to cut out on you? how long do you have to feather the gas when you start it up (i only do it for a few seconds with my current cam)... any and all info on it would be appreciated!
Old 01-31-2008, 12:49 AM
chuckyt1's Avatar
I don't drive it much but I would have no problem with it if I did.
Here it is at idle, not the best vid but you get the idea...
View Video on FQuick
Old 01-31-2008, 12:55 AM
chuckyt1's Avatar
On the Dyno with cutout open
Old 01-31-2008, 01:10 AM
jt76's Avatar
It idles well....... most vids i see on youtube are untuned cars that barely run... thanks for helping to clear that up. Sounds badass!
Old 01-31-2008, 01:17 AM
chuckyt1's Avatar
And now, the graph. The blue lines are NA
Old 01-31-2008, 12:38 PM
jt76's Avatar
anyone else want to comment on the street manners?
Old 01-31-2008, 03:14 PM
import slayer's Avatar
I DD my T-rex. It is the best cam that I have used so far and I have gone through 3 cams before that. As far as street manners, it really is all in the tune. I have a bad *** tune in my car and I have no issues at all.
Old 01-31-2008, 03:23 PM
Apollo0526's Avatar
I have found another cam that is almost like the trex. http://www.ls1speed.com/catagory.cfm...in%20/%20Heads It is a custom grind from comp # S17 238/244 .605/.612 @110 as far as i understand, the higher the dur, the higher in the rpm band you will make power.?? And the more lobe overlap, the wider the power band..?? What do you guys think
Old 01-31-2008, 11:47 PM
418redz28's Avatar
i didnt have to give it ne gas at start up... i had 4.10 gears and it bucked if u cruzed under 1700 rpms. sounds mean as hell and pulls very hard. i loved mine... im building a forged 347 and thats what it will have in it!!! cant go wrong!!
Old 02-01-2008, 04:27 AM
slowpoke96z28's Avatar
the more overlap the narrower the powerband will be generally.
Old 02-01-2008, 04:11 PM
moeZ28's Avatar
Numbers in my sig...not my car anymore, but thats what it did with 11000 miles on it, through a 9" with 4.10 gears. This was also a dynojet that consistantly reads 10% lower than any other dynojet.
Old 02-01-2008, 07:24 PM
Reject's Avatar
i say pass, you said you are going to go FI real soon. might want to get a cam more FI freindly
Old 02-02-2008, 01:45 AM
transamfreak01's Avatar
agreed.... this cam is too big for a FI car. look into some FI cams b/c this is not really a good match at all for it. if you stay N/A though then yeah this cam is mean as hell
Old 02-02-2008, 01:56 AM
quadd2244's Avatar
Totally off topic here but down where I used to live there was a kid with a trans am that was just cam only and he told me he had a trex cam in the car and he also had some kind of true duals. Now I have never heard a trans am sound more like a 6banger then this car did it sounded nothing like any cammed car I heard. I didnt even sound like a V8 for some reason. Well needless to say we did race from a dig and when he got around 4500rpm maybe or higher it sounded mean as hell and he walked me fairly easily but im mostly stock right now anyways but thats the first time I ever heard of the trex and he pronounced it t'rex like the dinosaur but it sounded terrible at idle and anything under like 4000rpm I dont know for a fact it was a trex but it sure pulled me very easily in the higher rpms but id say around 4500 it sounded mean as hell but still wasnt screaming but you could definetly tell it was cammed but anything under like 4500 sounded like a 6banger with no muffler. Il have to find out whats done to it this year for sure
Old 02-02-2008, 12:46 PM
97BlackLT1TA's Avatar
Im the one who bought moeZ28's car and after you get used to driving it its very easy to drive. I don't dd it because i have another car, but I could. You can definitely feel the difference when it comes into its power band as well, kinda cool. I say go for it unless your going FI, then I would look for something else.
Old 02-02-2008, 03:02 PM
jt76's Avatar
I plan on going FI/forged motor prob within the next 2 years.... i was just going to to with the Trex for a summer or 2... i just dont want something that is going to be a pain in the *** to drive, my current cam drives nicely.
Quick Reply: Anyone running the T-REX cam??
