Burkhart Chassis February specials.
LS1TECH Sponsor
Burkhart Chassis is having a sale on Moser rear end packages. We have outlined a few below. If you do not see what you want please pm for details and a price.
We are also continuing the sale on Aerospace brakes and can add them to the Moser packages. PM for Price.
Also outlined is a rear suspension packages to go with your new Moser rear end.
We will always work with you on our Fab 9 rear package. We have been selling these since 1994 and have them in some of the fastest LSX's in the country.
Moser 12 bolt:
With Spool bolt in 30/33 spline axle - 2100.00 shipped
With Posi and 30 spline axle - 2310.00 shipped
Upgrades:
33 Spline Axles $65.00
ABS (3 channel) or ABS/TCS (4 channel) $100.00
Exciter rings installed on axles for four channel option $100.00
Performance aluminum cover $135.00
Powdercoated $225.00
Lower control arm relocation brackets $100.00
Stock Style sway bar brackets $50.00
Moser 9":
Housing and Axle package up to 35 spline 1020.00 shipped
9" bolt in Spool 2200.00 Shipped
9" bolt in Posi 2425.00 Shipped
9" bolt in Locker 2525.00 Shipped
Upgrades:
Aluminum center section $155.00
Drain plug $35.00
Stock style sway bar brackets $50.00
ABS 3 channel option $175.00
ABS/TCS 4 channel option $100.00
Exciter rings supplied for 4 channel option $100.00
Add our CM LCA, CM PHB, and CM TA to any package for $750.00 shipped. This price good on a package deal only.
Moser 12 bolt:
Upgrades:
Moser 9":
Upgrades:
Drain plug $35.00
I just sent a PM about the housing and axel package, but now I see it. How much is shipping usually? That doesn't see any cheaper. Isn't the normal package $885.00+shipping.
LS1TECH Sponsor
I have some here:
http://upgradeadvantage.spaces.live.com/default.aspx
Let me know if these work. If you need specific ones I can take them off of mine.
LS1TECH Sponsor
Thanks for pointing out the typo. That's the problem with multiple people with too little time updating a web site. It should be 985.00. I'll get it fixed tonight.
Strange S-Case, 35 spline Strange Spool, Motive 4.30s, Alum. Daytona Pinion Support, Steel 1350 Yoke, Full install kit for Daytona pinion support w/ 3.250" carrier, Solid pinion spacer.
About $800 for those parts. BUT still need gears set-up. I have found that most of these sponsors have great deals, as I wont save very much buying it in pieces, however, I like the idea of my center being set-up by my local guy. That way if I have any trouble, I can go down the street and have it looked at. I'll have it all together for roughly an even $2000
