clutch grinding on takeoff
I tried to search but couldnt find much. It happened after the track. I know the clutch is going because it's starting to smell but I want to try and figure out if the tranny is going too. When I start from a stop kinda hard it grinds pretty bad but there is never any trouble getting into other gears. If I start out soft and get on it it doesnt grind but the clutch starts to smell. Also, If I do a burnout and press the clutch in the grinding comes back. Do you think it could be a problem with the slave or throw out bearing or are the synchros going out?
