Question about CNC machining finish
Old 02-06-2008, 11:28 PM
jebcamaro's Avatar
Default Question about CNC machining finish
I was wondering after a set of heads are CNC`d, do you have to smooth the machine marks left by the CNC process or can it be left like is?
Old 02-06-2008, 11:30 PM
Asmodeus's Avatar
You can leave it. Most people do. You don't have to smooth it out.
Old 02-06-2008, 11:34 PM
jebcamaro's Avatar
Great! thanks for the fast reply. The bowls were hand blended, so they are smooth. However the ports still have the machine marks in them. Didn`t know if that would affect anything.
Old 02-06-2008, 11:35 PM
Asmodeus's Avatar
No, a little roughness is good imo.
Old 02-06-2008, 11:36 PM
jebcamaro's Avatar
That`s what I have heard, but just wanted to make sure.
Old 02-08-2008, 03:25 PM
GuitsBoy's Avatar
hand blending (by a pro) is good and may coax out another HP or two. Its the ~80 grit roughness that breaks surface tension and is good for flow, not necessarily the tooling marks from a CNC program. Either way, itll be very close in power, and might not be worth the added price for the insignificant gain.
Old 02-08-2008, 06:48 PM
JPH
JPH's Avatar
have a pro cylinder head porter blend everything for you, it will pick up cfm.
