How much hp will a stock driveshaft handle?
Old 02-08-2008, 11:05 AM
tacklebox's Avatar
Default How much hp will a stock driveshaft handle?
I'll be ordering a 9 inch soon, but wondering if i'll need a new driveshaft too or if i'll be ok with the stock one. Any recommendations?
Old 02-08-2008, 12:04 PM
LS1TECH Sponsor
Steve Burger's Avatar
HP does not kill the driveshaft. Hooking hard will. What tire, gear, suspension, and HP level do you have?
Old 02-08-2008, 12:51 PM
tacklebox's Avatar
The car will have a 9 inch with 4.11 gears, running (as of right now) 275 m/t dr's. Suspension is basic lca's, phr, sfc's and also Qa1 shocks. My car put down 418hp on a mustang dyno.
Old 02-08-2008, 01:49 PM
105's Avatar
I'm interested to know this also, but I'm pretty we'll both be needing a stronger drive shaft. I plan on getting a heavy duty one with my 9", 4.11 gears, MT Street Radials. We'll be able to launch from really high RPM's which will kill the stock drive shaft at 400+ torque. Of course my car has an aluminum drive shaft stock. I'm not sure about yours.
Old 02-08-2008, 01:54 PM
14 Second Truck Club
mzoomora's Avatar
And weight.
Old 02-08-2008, 03:31 PM
Assman's Avatar
Also curious, I was coming on to post the same thing. I'm a mostly stock suspension with mods in sig and plan on running ET streets or something real sticky, will I need a new DS?
Old 02-08-2008, 05:15 PM
LS1TECH Sponsor
Joey@Tick's Avatar
For the money, it's tough not to suggest a new driveshaft when you're doing a beefed up rear end. A $400 driveshaft can save you hundreds of extra dollars if you break the stocker and it tears the bottom of the car up - or worse.
Buy a new driveshaft and sell your stocker to an LT1 guy.
Old 02-08-2008, 05:45 PM
bad6as's Avatar
we need to meet up some time.
i have friend who broke them on street tires. i was launching mine on slick and it never broke. i did have a viberation at speed thoe the front u-joint and rubber dampaner was going out. i bought a PST it took care of my viberation and it wont break
Old 02-08-2008, 06:04 PM
THROTTLEJUNKIES's Avatar
Well just to give you an idea, before the mods: Stock HP, Rear, Clutch...... everything 100% stock on a set of BFG KDW's. I got the tires hot enough and launched on some new blacktop 3 blocks from my house. Peeled it like an apple and ended up pushing it the whole way home. So yes, its not the HP.....its all how you hook my friend.
Old 02-08-2008, 06:23 PM
COOKIE MONSTER's Avatar
I got my Strange Chromeoly Drive shaft 3" with Billet Joints for 270.00 from Eric at Midwest.... Just a thought...
Old 02-08-2008, 08:37 PM
john563's Avatar
mine did that and took out my tourque arm tailshaft on my new tranny y pipe and put a nice gouge in the floor board
Old 02-08-2008, 09:06 PM
sixvi6-camaro's Avatar
Don't forget... Wheel hop will kill a stock DS with ease as well. I vote that Nobody should run a stock DS after they change to a 12 bolt or 9"
Old 02-08-2008, 10:25 PM
tacklebox's Avatar
Just curious, why would an LT1 guy need my old driveshaft?
Old 02-08-2008, 10:37 PM
mellowyellow's Avatar
They came witha steel one...
Old 02-08-2008, 10:44 PM
Slvr00Bird's Avatar
As did mine... Wonder why though... you wouldn't think a 00 3.8 bird would need one...
Thinking about aluminum though... take out some vibration at upper highway speeds..
Old 02-09-2008, 05:57 AM
EPP
EPP's Avatar
Thumbs up
That is exactly why we sell so many of the PST 3.5" alum driveshafts, rated at 1000 hp. Lifetime warranty and 10 years on the u joints. Bob
http://www.exoticperformanceplus.com....html?item=541
Old 02-09-2008, 08:19 AM
dirtdevil99's Avatar
Might as well get one, mine sheared when I was on drag radials.
Old 02-09-2008, 10:26 AM
Assman's Avatar
Ok, i'm going to order one but have a issue. I ordered my rear with a 1350 yoke but the new 1350 u joint wouldn't fit. Luckily I had another stocker and it fit like a glove, so does that mean I have a 1310 yoke? Trying to figure out for ordering purposes... Thanks.
Old 02-09-2008, 11:24 AM
Slvr00Bird's Avatar
Nice looking piece, but it says that it weights 2.5 (something like that) lbs more than the stocker... Is it talking about the aluminum stocker?
Also, it says that the u-joint won't mate up to the 10bolt.. What will it mate up to without a conversion kit from Napa? And any idea how much the conversion kit is?
Thanks
Addison
Old 02-09-2008, 03:20 PM
suprsiz3_ls1's Avatar
I just bought a 9 inch with a 4.56 gear and I need a new drive shaft, if I bought the PST 3.5 will I be able to launch with slicks around 3-4000 rpms and not break the drive shaft?
Quick Reply: How much hp will a stock driveshaft handle?
