Difference between 99 and 2000 ls1 engines?
Old 02-12-2008, 02:16 PM
Automaticfastic's Avatar
Default Difference between 99 and 2000 ls1 engines?
I have a 98 firebird (formally a v6) with a 99or00 ls1 in it. I know this because of the stock injectors are 26 pounders. How can I find out if its a 99 or a 2000?
I do have full exhaust, cam, (853 stock heads) ls6 intake, blah blah. So I dont know what else I can look for that will tell me what year it is. Any advice? Thanks, Auto.
Old 02-12-2008, 05:16 PM
Gipraw's Avatar
Check this FAQ .. should answer your questions.
https://ls1tech.com/forums/showpost....80&postcount=2
Old 02-12-2008, 05:44 PM
mojolamar's Avatar
The casting numbers on your heads will tell you if it's a 99' or 00'..Yours is a 99 b/c you have 853 heads like mine and although you might not like them they are way better than the shitty 98' heads which were mostly 806's and flowed like my uncles toilet after thanksgiving dinner...not so well lol
Old 02-12-2008, 06:29 PM
5w20's Avatar
interesting
Old 02-12-2008, 06:36 PM
cool that helps. Now I know why my coolant temp sensor didnt work. 98 years r different......... Thinking about doing a turbo setup and it would help to know what year my engine is. Thanks guys.
