Crane Cams HI 6R ?
Old 02-14-2008, 08:31 PM
dirk70301's Avatar
Default Crane Cams HI 6R ?
I 've recantly installed a Crane Cams HI 6R Ignition with the high output coil on my 94 Z28 project . Was wondering if I should leave the IGNITION CONTROL MODULE pluged or if it needs to be removed . Im not using the factory coil and the car isn't up and running yet , I can,t start the car to cheak the differance .
Old 02-15-2008, 06:03 AM
SRZ
SRZ's Avatar
You have to keep the ICM.
Old 02-15-2008, 07:15 AM
The Engineer's Avatar
The ICM fires the coil, here is the OEM wiring diagram.
WD
Quick Reply: Crane Cams HI 6R ?
