looking for a r&r of the factory rear end!
I have a 00 formula and am preparing to swap a 373 rear end into it! It is a complete rear end so the only thing that will be removed from my old rear end is the rotors and calipers. It is a abs & traction control rear end!
Does anyone have a write up on remove and replacement of the stock rear end!
Thanks, I tried a search but i could not find a process!
Here is one for installing a 12 bolt, I know you're doing a 10 bolt - but at least this tells you how to get the old one out. Once you have it out it'll be simple to figure out how the new one goes back in.
https://ls1tech.com/forums/gears-axles/514327-how-install-12-bolt.html
