What size tires? Spacers?
Closed ex-Sponsor Account
What size tires for prostar skinnies up front and what is the smallest spacer i can use without grinding on the brakes up front? Also are new wheel studs required or can i get longer shank lugs?
-Matt-
-Matt-
Location: Your girl's back door giving her the long stroke while you're at work
If you are running 15x3.5 then you will have to run a 5/16" spacer. It would be wise to get longer studs also.
You can run either 165R15s or 26x7.5x15 M/T Front Runners
i think mine are the 165's but there still belted. i will get the brand and everything tomorow. my buddy has the same tires but not steal belted and they sag bad, mine stand up strait
I appreciate it man i promise i will get some really nice picks up on here when i get done with everything hopefully next weekend sometime i will have the summit stars 15x4s up front and weld prostars 15x10s with 325/50/15s in the rear
