Hard to get into reverse
Old 02-19-2008, 06:51 AM
vhgjk123's Avatar
Default Hard to get into reverse
I noticed its been getting harder to put the car in reverse. This morning it took alot of strength to get in that gear. All the other gears work completely fine. What do you think is the problem? shift fork? tranny going out?
UPDATED: see 5th post below this one
Old 02-19-2008, 06:55 AM
vhgjk123's Avatar
I just did a search and saw possible eng sen fuse blown. I will check that today.
Old 02-19-2008, 01:24 PM
Black FormulaLs1's Avatar
good luck mine did that too and i replaced sensors and stuff but my tranny still finally crapped out and i plan on getting it rebuilt with new sensors and callin it a day
Old 02-19-2008, 01:31 PM
2001NBMZ28's Avatar
Usually the eng sen fuse will throw P0102, check it, but if it's been getting progressively worse over time probably something else.
Old 02-19-2008, 02:21 PM
11Second Club
Gauge's Avatar
Are you having trouble pushing it over to the right, or pushing it up into gear? If it's an electrical issue, the solenoid will prevent you from pushing the shifter far enough to the right. If you have trouble pushing it up into gear, then it's probably a mechanical problem in the transmission or in the bellhousing.
Old 02-20-2008, 01:01 PM
vhgjk123's Avatar
The problem is pushing it into gear. I replaced the fuse but it didnt help at all.
Old 02-20-2008, 09:10 PM
nasty96's Avatar
i would bet on the hydralics the ls1 cars are known for that failure..try pumping the pedal and see if that works ... 1st should be the same way though most of the time... or try going to 1st then reverse ...
Old 02-20-2008, 10:28 PM
11Second Club
Gauge's Avatar
If it's hydraulics, you should sense the problem with every gear, even if it's only sporadic. Reverse tends to be the worst, but you'll still notice it with the other gears. If you're having trouble just pushing it up into reverse, then it's probably an internal transmission problem.
Old 02-21-2008, 05:25 PM
vhgjk123's Avatar
well i just noticed yesterday that 1st gear is becoming slightly more challenging to shift into. The other gears still act fine though
Old 02-21-2008, 06:00 PM
JimsWS6's Avatar
It might be the shift fork. I know my brothers 02 WS6 when he got it used 3 yrs ago it would pop out of 2nd. There was a bulletin my dad found (he works at a chevy dealer) on the shift forks. I guess some of them were like aluminum? and some were cast iron. So they replaced it with a cast iron fork. Fixed it. I know your concern is on reverse, but maybe it's a similar issue.
I noticed when I got my car last yr I changed the fluid to red line synthetic like GM called for and it made all the shifting feel smoother, but then i'm having problems getting in into reverse sometimes
Old 02-21-2008, 10:55 PM
ErikElvis's Avatar
About every car I have had had some trouble getting into reverse when cold. I usually just go into 1st then reverse. If its doing it warm theres prob more to it.
Old 02-22-2008, 12:05 AM
Gun5's Avatar
yep just how they are.. although change your fluid and bleed your clutch mine took 2 hands now can do it decently easy
Old 02-22-2008, 01:55 PM
vhgjk123's Avatar
Its difficult to get into reverse all the time. It takes two hands and almost full strength to get it in reverse when cold. when its warm i can do it one handed but its still pretty tough.
Old 02-22-2008, 02:46 PM
johnnybravo's Avatar
Ditto. Put it in 1st, ease the clutch out just enough to roll the car a tiny bit, then clutch in and shift into reverse. If you're forcing it, you're gonna break something.
Mine was doing that, I changed fluid, and there was a noticeable different. Went right into reverse, even cold, and shifted smoother all the way around.
Cheap fix, I like that.
Old 02-22-2008, 11:00 PM
LS1Silverado05's Avatar
What fluid did you go with?...
Old 02-23-2008, 11:17 AM
Castrol Dexron / Mercon. The description on the bottle said it met all the requirements of Dexron III, so in it went. Got it at Auto Zone.
Quick Reply: Hard to get into reverse
