CID, Stroke, and a Turbo???
Was searching for some info on this and would like to run a turbo but I want to understand what combo works best before I spend any money.
Correct me if I'm wrong on any of this. I'd like to run a T4 flanged 76mm on a 6.0L iron block for the 4.00 bore so I can run the L76/L92 combo. I was thinking of maybe running a 5.3 or 4.8 stock crank with forged pistons and H-beam rods. Will this work so far? I'm not to sure of what the CID would be after those cranks but according to my research running a 76mm turbo would work well with the smaller displacements. I know running pump gas isint the best for higher boost levels but I'd like to run 93 with alchohol injection. Please critique me and let me know if this will work and give me some input. TIA!
Smaller motors will make progressively more power with a T4 flanged 76, down to at least <200 cid, BUT YOU HAVE TO RUN BIG BOOST NUMBERS TO SEE THE ADVANTAGE. So, I like your idea. A 4.8 crank would make it 328 cid or so, which should work well. Make the cubes small to get the pressure ratio's in check, then use good heads/cam to make it rev and make good power/psi boost.
Mike
Mike
Mike
Mike
Yup, the deal was outrageous and had many, many extras, I mean it was almost a COMPLETE kit, LOL The guy is going to help me install, should be cake since he's already done it. I was originally going with a D-1 but like you said hard to pass up a great deal and it should make 800rwhp on pump/meth
I have a 76GTS from Forced Induction for sale. I bought it last year and never installed it. I changed my displacement plans and now have my 408 close to completion. I need a larger turbo for my 408 so I need to sell my 76GTS. PM me if you are interested. You can also ask Forced Induction about my turbo, they know of my situation.
5.3 crank is a 6.0 crank is a LS1 crank is a LS2 crank w/24x
3.622 Stroke x 4.0 Bore= 364.1cu.in.= 5966.92cu.cm.= 6.0L... I've heard of that somewhere? The way to go on pump gas. As for turbo size... I flunked that class
Good luck with your decision, as long as you research and take your time deciding it will all fall together and work out nicely. Try to think of it as a whole package and make it work for what you want to do. Powertrain, drivetrain, power adder, suspension, fuel system, etc, etc. Thats what I did. Heads, cam and intake are another huge one tha compliment the system.
