Offset Lifters?
Offset Lifters?
Have a Gen V 502 block and I'm retro fitting it with solid roller lifters. Everytime I look for lifters I keep seeing offset lifters available. When exactly would you use offset lifters and how would I know if I needed them. Thanks!
Anthony
Anthony
I'm using RHS 320cc heads with 2.25/1.88 valves. Why would a large valve require offset lifters? The only thing I can come up with would be for pushrod clearance with the head, but I've never delt with them before so I don't know.
offset lifter are used on large port heads or where the ports have been moved like on big chief heads,and your exactly right its for pushrod clearance,there are plenty of non offset roller lifters out there for bbc
Thanks, so more than likely I don't need them, but it's always good to mock up the heads and make sure. I was originally going to use Crower cut-a-ways, but I was wondering if people have had good experience with the Comp Endurex lifters. Any input? I will spend the $650 if it's truely worth it, but I would rather spend $380 if they will get the job done.
Well I went ahead and ordered the Comps a few minutes ago (888-16) from Motorville for $425 so hopefully everything will work out. If I post back in a month or two with a major problem you'll know why, lol. Thanks guys!
