BOV Question
BOV Question
Tried the search and couldnt find anything.Was just wondering if you should run a bov with every turbo application or should you be at a certain boost level before you need one.This is for an automatic tranny application.
Thanks
Brad
Thanks
Brad
I was told at one time that they were basically for m6 cars and when you look under turbo faq it says they are more for manual tranny's.But I thought that it wouldn't matter the type of tranny.If your makeing boost and the throttle blades shut when you let off the gas then you have backpressure.But I figured I would ask you guys because there are alot of nolidgeable people on this site and I appreciate all the help I have recieved over the years.
Thanks
Brad
Thanks
Brad
I will be running a 408 with a t88.I have a STS kit now but may be going to a frontmount if I cant fit the t88 In the back.Either way I will only be runnig 10 to 12lbs of boost.(Probably)
