Stock PCM limits
Old 07-16-2003, 10:17 PM
Evil F1 SS's Avatar
Default Stock PCM limits
What are the LS1 "01" PCM's rwhp/rwtq tunable levels.Why does 650 HPseem to be the limit? Some cars with biger motors and more radical cams make less peak HP than a smaller ect?? I am having my car dyno tuned and should be hitting these limits. Are there any oiptions besides a stand alone PCM?
Old 07-17-2003, 03:52 PM
Cal
Cal's Avatar
Default Re: Stock PCM limits
350 lb-ft is the stock setting, but you can change it to 640 lb-ft. That's the limit of the stock PCM.
Old 07-17-2003, 06:11 PM
NoGo's Avatar
If you have a savy tuner, I don't think there are any real HP/Trq limits with the stock PCM. The only real limit that I don't know of anyone surpassing is the 8000 rpm limiter.
JMO
Old 07-17-2003, 11:39 PM
Cal
Cal's Avatar
The problem with putting in 640 or higher is the value will wrap around actually giving you a lower torque value. Here's a direct quote from Ken Kelly of LS1edit:
"The PCM treats torque as a signed number. Numbers over 639 set the most
significant bit. When the actual stored value gets the most significant
bit set, it is treated as a negative value.
Ken"
Old 07-18-2003, 01:04 AM
66ImpalaLT1's Avatar
512 gm/sec air flow
