Broken widow washer
Broken widow washer
Good day, the previous owner of my 02 camaro put water into the window washer container and I think calcium has built up in the line, pump, or sprayer. When I spray the fluid the passenger side leaks out and the driver’s side sprays fluid over my T tops and onto my back window What do you guys recommend? Thank you.
The sprayer end tip is clogged up. I dissasembled the tip with a small jewelers screwdriver and there was some trash in the orfice.
You will have to remove the screened cover under the wiper blades.
Save the manuals!
Soak the nozzles/parts in vinegar. That will dissolve any calcium deposits.
If you have a hard mass clogging the line or the nozzle, you can also hook up a vacuum pump (from a brake bleeder system) to the line, dip the nozzle in water, and then suck water backwards through the line.
Not sure about the F-Body removal - did the above on a truck with a similar problem.
