compblower cam and pushrod length
I got some great info from Vettenuts over on corvetteforum, but before I install my new pushrods, I have a question about the length.
I put in ported 243 heads and a comp cams blower cam. The valves were oversized, so they are not the LS6 hollow/sodium filled valves. When measuring with a comp cams pushrod length checker, 6.800" - 7.800" I turned it 9.5 turns to where the rocker was not tickig on the valve stem, but no pressure on the lifter. That gave me a length of 7.275. I then added .100 for lifter preload for a total of 7.375".
My question is why do I calculate a shorter than stock pushrod? it is my understanding that the base circle for comp cams is smaller than my 97 LS1 stock cam.
Any thoughts?
Any thoughts?
I installed the 7.375 rods. It took 2 turns from the time the rocker stopped ticking to the 264lbs/in torque spec. Does that sound correct? I have read conflicting thoughts on the subject.
Are your heads milled? Which gasket are you running.
What are the cam specs (lobes)
22lbs/ft is your trq on rockers, that has to be done on base of cam lobe. 2 turns sounds like your p-rods are too short.
