Oil puddled on intake valves, help
I am having an issue with the oil in the intake, well actually it's in the combustion chamber and working it's way back up into the intake (reversion). I also removed the PCV all together because of oil in the intake big time (could feel and see oil in the TB neck). So after blowing my ls6 intake I put a ls1 on and washed it out realy good to follow the oil issue. Now I took the intake off to put the single plane on and noticed oil around the gaskets between head/intake hmmm... So, I check the intake out and oil is not in the plenum, so this indicates it's coming from the cylinder heads/combustion chamber. I look inside the intake ports and six of the cylinders that had the valves closed had a teaspoon of oil sitting on the closed intake valve. Still haven't figured it out. But feel it must be coming down the valve stems. The heads are stock LS6 with a new valve job. I have also heard of others with a similar issue running the 408 with no PCV, related? Any insight out there?
Here's a quote of another similar issue. Both 408s were built by LME, and I know mine has some loose rings .028 top and .021 second (built for a 300shot). Could oil be coming up past the rings because of the PCV missing and the engine just trying to breath?
Robert
I don't have any kind of PCV on the car, just a vent on the valve cover leading to a breather. I did notice (for some reason) there was oil in the intake after 4k miles, quite a bit actually. I don't know where it's coming from or how it got there. The only way would have to be some kind of reversion in the ports or something and somehow blowing oil back into the manifold, but that would mean the valve seals would have to be worn out and they're brand new. The cam has 20* overlap.
Oil sitting on the top would seem to be messed up valve guides and/or valve stem seals. But I suppose it could be from blowby due to the losse rings with no PCV.
Robert
I would try that first. I like to use the Permetex thread sealant on the threads of the rocker arm bolts. I placed it about a 1/4 inch from the end of the threads on the bolt. This places the sealant right in the middle of the threads. It is about the easiest and cheapest thing to do to try and solve the problem. If this does not help then I would look at valve stem seals. I seriously doubt you are getting enough blowby to revert that much oil ontop of the valves. I would look at sources of oil from the heads first.
Update: I checked the manual and it says nothing about sealing the rocker bolts. Also, I can feel the boss for the intake valve rocker bolt and they do not protrude through the casting. Remember these are bone stock LS6 heads. Is something different on the exhaust rockers, as I still have heads on car with headers and can't see or feel into the comb chamber like I can the intake.
I talked to the shop that put the heads on the motor and installed motor, and they said I may have hurt the rings when I had my nitrous back fire, though I doubt that all the cylinders could be hurt as some of the valves were closed, unless cylinder pressure from below comprimised the sealing ability. I wll be doing a cylinder leak down on that issue.
Robert
