Koni installation woes.
I think I may have bitten off more than I can chew with this install.
The rears were a breeze. I believe I finished both in about 2 hours.
I installed the front passenger side shock and and now I'm getting a sound coming from the passenger side. It occurs when I hit bumps in the road, or when the body of the car moving through turns sort of. Kind of like a clunking, mixed with a sound you hear when metals scrap each other..
After reading some of the threads in the forum history about problems with install, I'm actually scared to further take it for a drive as I'm scared to blow out the shock. I pulled the wheel, and went to retighten all the bolts and everything that I had to disconnect. Everything seemed normal, other than the fact that my Koni looks like it's been on my car for 100,000 miles.
http://picsorban.com/upload/shocks2.jpg
http://picsorban.com/upload/shocks1.jpg
http://picsorban.com/upload/shocks3.jpg
I had a problem with the getting the bolts at the bottom to line up when I had the shock mounted to the LCA. If I tried the opposite way, the bottom wouldn't line up. So I ended up banging till it went into place. Hopefully I didn't damage anything.
On top of that, the guy at pep boys was a total dick, and wouldn't install shocks on the spring so that the window was facing outward..
And to think, I actually lucked out and didn't get a nut that was rusted away..
how was the big rubber boot on top of the shock? the reason i ask is that mine was really hard to get off of the old shock. I finally got it off but ended up damaging it a little bit. Well when i put it back on with the new shock-spring it made the same noises you describe. Well i ended up having to replace the boot and the sounds went away.
P.S. I had to get the part from the dealership
What part is the boot?
I don't remember using anything from the stock shocks. I took the Koni as it looks
http://picsorban.com/upload/shocks344.jpg
The boot that you are talking about, is it what is pictured to the right of the stock shocks?
It could be the nut at the top of the shock pictured here. http://www.ls1howto.com/howto/fbody/...s/IMAGE017.jpg If it's not tight it will definitely make some noise. Also pictured is the boot nick1ta was talking about.
