grinding booboo
grinding booboo
wel i was grinding for my new 15x8 draglites when it broke through the caliper bracket. ***** hollow! not a very big break just about half the size of the moon on your thumb. what should i do to fix this? hard putty? weld? thanks again
thanks for the help in advance!
wow, ground a little much off, lol. were you fitting as you were grinding or did you say fu*k it and went to town. I don't know if that is going to hurt you or not, i would think it would being it is lubricated w/ grease.
ya im getting new brackets and regrinding. i had the wheels off and on the car a bunch of times and the last time where i broke it, and went too far because i was sick of putting them on and off.
also, in an other thread gm muscle had a similar issue:
in this thread: https://ls1tech.com/forums/showthrea...ng+caliper+pin
how is his booboo different from mine?
That's interesting.... I never saw that before. Does grinding down the caliper and bracket sacrifice any of the structural integrity?
That's not a hole in the end of the caliper bracket is it? That would be awkward if you were forcing out the grease from a hole in the back.
Now that I'm home and the first set of pictures aren't blocked like they are at work... I just noticed the above pictures.
Yeah that doesn't seem like such a good idea There's a hole on the other side of the bracket. That's where the caliper pins slide and are lubed. That looks like an accident waiting to happen.
