v8 into v6???
Old 03-02-2008, 09:21 PM
saylorZ28's Avatar
Thumbs up v8 into v6???
hey i got a freind who is putting an lt1 into a v6 car i did a search for him didnt find much but what all does it take to do it and make it work what all do you have to change .... i will continue doing a search and change my key words
Old 03-02-2008, 09:26 PM
sweet-94z28's Avatar
K-member, V8 engine, V8 trans., PCM matching whatever you are running.
Old 03-02-2008, 09:27 PM
Slvr00Bird's Avatar
It depends on the year of his car, the options it has, etc... I'd say find a good installer that has done it before and that can do wiring and tuning and let them do it.. Thats the route I took and it turned out great.
But to basically answer your question.. K memeber, front springs, engine mounts, engine, tranny, computer, ac lines, different fuel pump or some custom plumbing with a different fuel filter, headers, intake, and then a bunch of odds and ends..
Also, if your friend is going to dump all this money into it, why doesn't he just go ahead and try and find a decently cheap LS1 to put in instead of the LT?
Old 03-02-2008, 09:32 PM
balzyz28's Avatar
Why LT1?
Old 03-03-2008, 08:26 AM
LT1forever's Avatar
Originally Posted by balzyz28
Why LT1?
Their fast, loud, cheap and have pretty good longevity.
Old 03-03-2008, 09:55 AM
Slvr00Bird's Avatar
Opposed to the LS1 which is?? FastER, loud, can be found for cheap and has good longevity.
Old 03-03-2008, 12:19 PM
LT1forever's Avatar
You can make some pretty sick engine combinations with either. I chose the LT1 because I thought it sounded mean as hell and the body style looks killer as well. I dont see why everyone bashes it so much it isnt slow by any means. I could see switching to the LS1 if I were a serious racer. But I doubt I ever will be, so in the mean time I'll drive around my modded LT1, be happy, and play the role of the underdog.
Old 03-03-2008, 01:17 PM
camaro-94-z28's Avatar
mods are cheaper for lt1. gas millage is better (i Believe) and id rather mod an iron block then a aluminom block. but stock for stock ls1 is better
Old 03-03-2008, 02:10 PM
Slvr00Bird's Avatar
To each his own.. I say if you already have a LT1 laying around or can get it stupid cheap then go for it.. I've seen some really impressive numbers out of LT1's.
Old 03-03-2008, 07:45 PM
LT1Formula007's Avatar
LT1 ALL the way baby! Cheap to buy, Cheap to Build, and still put down VERY impressive #'s for half the cost of an LS1.
LS1's are way too over-rated, Too high, to much to mod, and have a tendency to pop under nitrous too easily. And it's usually the # 7 Cylinder that goes first. If you want an LS? based engine go with at least the 6.0L LS motor My .02 though!
Keep us updated if he goes through with the swap....
James
Old 03-03-2008, 09:20 PM
saylorZ28's Avatar
Question
well he got a great deal on a donor car that ran but we installed it this weekend and it wouldn't start we checked everything ... it would crank but it wouldn't fire ... it would only fire after you let off the key we changed the opti and everything.........we cant figure it out ,..... anyone have a clue
Old 03-03-2008, 10:49 PM
Slvr00Bird's Avatar
Yea if it acts like it wants to fire but after a loooong time of cranking (10-20seconds) you finally decide to stop and then it acts like it wants to turn over then it's probably the cam or crank sensor...
My car had similar issues but would start every now and then and it was the cam sensor..
Quick Reply: v8 into v6???
