Brake Master Fluid Emergency!!!
Old 03-06-2008, 05:10 PM
The_Wretched's Avatar
Default Brake Master Fluid Emergency!!!
kind of like overnight my clutch went from firm to soft and stalling out at a lower point to the floor.
i haven't been burning clutch. well i checked the clutch master resevoir thing and it is empty.
so would that be the issue or is my clutch out???
it was perfectly fine 2 days ago....
what kind of oil should i pick up and to where do i fill it up???
no leak... that i am aware of... there's no leaks on my driveway....
this is my first stick car too by the way...
Old 03-06-2008, 05:15 PM
it says to add if below the plastic step... wtf is a plastic step???
Old 03-06-2008, 05:21 PM
sorry the part is actually called Hydraulic Clutch
Old 03-06-2008, 06:12 PM
chuckyt1's Avatar
The "step" is inside the reservoir. You can see it when you look inside it. Use DOT 4 brake fluid to fill it. You're going to need to bleed the system also...
Old 03-06-2008, 06:21 PM
ae13291's Avatar
yes hope that the slave cylinder dident crap out on you, but you can try first by filling it up with some good brake fluid DOT 3 or 4 witch ever one (DOT 4 is the better choice) and then you have to get under the car to bleed the system so all the air is purged
