Self align rr's vs. NSA
i read the write-up's for cam section and im still not clear wich one is better for cc503 cam and stock engine unported heads ect.
whats the advantage of self aligning RR's?
whats the advantage of none-self aligning RR's?
Anyone know which one to run on cc503 and what brand RR's to use? i would like to go with 1.6RR's and whats better 7/16 or the 3/8 stud. The write-up cam section says 7/16 stud is stronger. i just need more info the write-up's unclear for me.
do i have to check vavle geometry with NSA rr's?
I run SA Comp Cams Magnum 1.6's right now with a 3/8 Stud. They work great, the shop that did my install told me the NSA's would be overkill so I took there word for it. However, when I put my a new cam in next month I'm going to swap in some NSA Comp Cams Pro-Magnum's with a 7/16 Stud. NSA are really important when running at higher rpm levels so the rockers cannot slip off the valve tips but Im doing it for peace of mind. If you do go with NSA you will need to get hardened chromemoly pushrods, guideplates, and studs. If you plan to add heads down the road I'd go NSA but for stock heads and the cc503, SA will be fine and NSA will be cheap insurance so its up to you.
had few more questions if i went with NSA comp cams pro-magnum 1.6rr with 7/16 stud and Trick flow chromemoly pushrods 7.200" which guideplates do i use?
http://store.summitracing.com/partde...8&autoview=sku
One is flat and other is raised, whats the difference and which one do i use?
I finaly got a list of things i'll need for my cam swap, wondering if theres anyother place i can buy them for cheaper?
CCA-1305-16 Pro-Magnum Rockers 7/16" stud (1:6 ratio) $285.95 summitracing
CCA-07-503-8 CC503 (224/230 .503/.510 112 LSA) $259.95 summitracing
CCA-26918-16 Beehive Spring $189.95 summitracing
12499225 LS7 Lifter Kit $107.85 SDPC
TFS-21407200 Trickflow 5/16 Hardened Chromemoly Pushrods 7.200" $86.95 summitracing
CCA-795-16 Steel Retainers (LT1 for 918 springs) $52.95 summitracing
CCA-4705-16 seats $44.39 summitracing
ARP 134-7103 Arp (Rocker Arm Stud) 7/16" $36.95 summitracing
CCA-611-16 10 degree Lock (11/32 super lock) $22.88 summitracing
TFS-30400623-8 Trick Flow guideplates $15.95 summitracing
Total = $1103.77
Total = $1103.77
I know you have the cc503 planned(what im going to be using aswell) but you might check out the Advanced Induction cam kit aswell, has everything you need and is about 100 cheaper.
http://www.advancedinduction.com/AiProductsCK.html
I wouldve gone this route but already had rockers and found a good deal on my cam.
