Looking for expierenced insight on a Cam for my LS1
My mods are in my sig. First off I don't want to regret getting a cam. I am looking for some HP gain but I don't want a really rough idle.
My Q- What is a good cam that I should look into getting and what else should i do while installing the cam (rockers,lifters,springs?)
Thanks guys
Thanks guys
Here is a link that you will probably be interesed in: https://ls1tech.com/forums/dynamometer-results-comparisons/873906-04-c5-smooth-idle-build.html
Talk to Ed he has all kinds of ideas that could help you out.
PredatorZ and Patrick G. also good ones to talk too on here. If you want a smooth idle you will a 114-117 LSA on the cam. The also the more overlap you have the choppier the idle i believe. My suggestion would be to talk to either one of these guys or Ed too. Get a cam spec'd for your specific application.
